Dexterb
- Sep 3, 2022
- 4
When idling the pedal shaft shakes and clatters. If I push forward slightly on the pedal it reduces this activity, which simply seems to reduce tension on the pulleys and the belt. If I just hold the pedal tightly with my hand it stops clattering too. I replaced the worn drive belt and the clattering now is a little louder. It seems like maybe the idler pulley is bouncing a lot. Should it bounce this much? What kind of adjustments can be made to reduce the clattering noise?
Here is a 20 second video showing this behavior:
