I have a LA105 John Deere mower with 514 hours on it. I have started hearing a winning noise from the trans axle. It looks like it is a sealed unit does it have oil in it or just packed with grease. Would like to repair it if possible.
Thanks RT for the information. It is a big help.If the IPL is correct you have a manual Peerless transaxle and it uses 00 grease which I sub for the Bentonite grease.
