L Lynnkey58 Forum Newbie Joined Apr 21, 2015 Messages 2 Aug 24, 2023 #1 Hustler Fastrak model 926501, engine at idle, moving throttle doesn't change RPM's. What can I check? Thanks in advance!
PTmowerMech Lawn Addict Community Leader Joined Apr 16, 2018 Messages 3,546 Location Arkansas Aug 24, 2023 #2 Lynnkey58 said: Hustler Fastrak model 926501, engine at idle, moving throttle doesn't change RPM's. What can I check? Thanks in advance! Click to expand... Model number of engine is needed. Off the top of my head, is the throttle on the carb opening when you work the throttle lever?
B Bertrrr Well-Known Member Community Leader Joined Mar 11, 2021 Messages 652 Aug 24, 2023 #3 Is the linkage working ? does it move the throttle plate at all ? might have just come loose from the cable mount
