No throttle control
Lynnkey58
Hustler Fastrak model 926501, engine at idle, moving throttle doesn't change RPM's. What can I check?
Thanks in advance!
PTmowerMech
Thanks in advance!
Model number of engine is needed.
Off the top of my head, is the throttle on the carb opening when you work the throttle lever?
Bertrrr
Is the linkage working ? does it move the throttle plate at all ? might have just come loose from the cable mount
