mowin4dodge
- Mar 11, 2012
- Threads
- 1
- 5
Grasshopper 722d2. Had a no start problem. wired up a push button starter and had slow crank. replaced starter and starts fine with the push button but will not do anything using ignition switch. Getting 5 volts in start position at solenoid from switch wire and 10 volts at start fuse. Ignition bad too?
