no start
mowin4dodge
Grasshopper 722d2. Had a no start problem. wired up a push button starter and had slow crank. replaced starter and starts fine with the push button but will not do anything using ignition switch. Getting 5 volts in start position at solenoid from switch wire and 10 volts at start fuse. Ignition bad too?
mowin4dodge
Well I had another switch here and changed it same out come. pulled both relays and cleaned and same still. going to try and change relays and see if that gets it. They only have one in stock so will pray only one is bad. other wont be here till wed.
mowin4dodge
Relay bad. :) SOOOOOOOOOOOO Im good. Well except for all the other crap to fix before season starts and that could be any day!
