No Start - New Ignition Switch
BobDonut
I recently got a Toro Wheel Horse riding mower. Model 3212O502
The ignition switch wasn’t automatically snapping back to “run”, so I figured I would replace it with a new one. Here is the new ignition switch.
Now I blow the 25A fuse every time I try to start the engine. I tested the posts on the ignition switch, and all seem to work as they should, except I don’t get a connection when I test the ground post to the body of the ignition switch.
Any ideas what should I check next? Or does no ground to the switch body mean there is something wrong with the ignition switch?
thank you!
Fish
Look at the side of the switch with the prongs, there should be a letter on or around each prong.
Compare it with your old one. Improper switch can damage your ignition coil, so be careful.
BobDonut
Thank you.
These are the two ignition switches. The older one doesn’t have letters on it but I can see that it looks like the posts are in a different order, just based on the one with the gold connector being in a different spot.
Any educated eyes out there know what I should do to confirm if they are in the same order? And if not, how can I make it work or find the right ordered switch for my tractor?
Thanks so much for the help!
BobDonut
Sorry if this is a stupid question - how can I tell which switch is mine? Or should I just buy the other one and see if it works?
Scrubcadet10
Moderator
Staff member
I think one of the real experts will have to answer that question...
i would imagine the numbers in parenthesis has something to do with identifying them.
Fish
It would be dependant on which engine you have on that tractor. Also, what is the model number on the hood?
Is it 212-5?
Fish
Also, find and post the model numbers off of the engine.
Fish
Or a quick pic or two.
Fish
On the gray switch, look closely at the terminal blades for letters.
