BobDonut
- Jul 6, 2020
- 1
- 5
I recently got a Toro Wheel Horse riding mower. Model 3212O502
The ignition switch wasn’t automatically snapping back to “run”, so I figured I would replace it with a new one. Here is the new ignition switch.
Now I blow the 25A fuse every time I try to start the engine. I tested the posts on the ignition switch, and all seem to work as they should, except I don’t get a connection when I test the ground post to the body of the ignition switch.
Any ideas what should I check next? Or does no ground to the switch body mean there is something wrong with the ignition switch?
thank you!
thank you!
