Mad Mackie
- Jul 11, 2011
- 1,851
The first thing that I do is to install a jumper on the seat switch, if that corrects the cranking problem, then I know it is the seat switch. The clicks that you are hearing probably is the fuel shutoff solenoid, it shouldn't click but stay on or off in the cranking cycle.
With your machine still on warranty, you need to be careful that you don't void your warranty by doing things that a sharp tech can pickup on when he performs checks on your machine at their service place. When I did full system checks on my machine I had to have a 2nd person and a 2nd multimeter. Eventually I learned the system with the wiring diagram in hand and did partial system checks progressively thru the system.
Mad Mackie needs to crash as it is getting late!!
Later
Mad Mackie in CT
Later
Mad Mackie in CT
