tigercat,
On the engine starter mounted solenoid there is a green with white stripe wire, this is the cranking circuit from the machine electrical system and should have battery voltage at it when all the safety circuits, key switch, cranking relay and safety interlock module are working properly and all the electrical connector plugs/terminals are clean and making full contact. The electrical connectors are as follows;
On the underside of the panel with the keyswitch, PTO switch, etc, there are connectors on the keyswitch, PTO switch, and the cranking relay. The yellow wire on the keyswitch is the charging system output from the fuse with the yellow wires. Remove both fuses before attempting to clean these connectors, reconnect all. Inspect and clean the fuses, reinstall them. Test crank the engine.
Disconnect the battery positive before opening and cleaning the remaining connectors which are the safety interlock module, both lever switches, parking brake switch and seat switch. Reconnect all connectors and battery positive cable. Test crank the engine.
Initially you can do some checks on your machine, follow my list.
In the high amperage circuits which include the battery and all connections, check the following;
Disconnect the positive and negative connections on the battery, clean the cable and the battery posts and reconnect. Test crank the engine.
Follow the battery ground cable (black) to where it connects to one of the engine mounting bolts, there may be other ground wires connected, remove bolt, clean, inspect and reinstall on mounting bolt, tighten bolt and nut. Test crank the engine.
Follow the battery positive cable (red) to where it connects to the start solenoid on the engine starter motor, check the terminal for security, bear in mind that this terminal is hot with full battery power, so disconnect the battery positive if you decide to disconnect this terminal to clean it. There is also a small red wire connected to this terminal, this is the supply for all the power to the machine except high amperage. Reconnect anything disconnected and teat crank the engine.
The small red wire on the start solenoid is the source for all machine power, it connects to the machine electrical harness thru the Kawasaki FX engine adapter harness. Disconnect the battery positive cable, find and disconnect the engine to machine connector, inspect and clean the terminals, reconnect, reconnect the positive battery cable. Test crank the engine.
Tomorrow there will be a quiz!!!!! Haha!!!!:laughing:
Mad Mackie in CT:laughing::biggrin::smile:
