Craftsman Rider with B&S 44S877 V twin motor. Had to put a stator in it. Also changed the oil, filter and air filter and new plugs at the same time. Ran fine for about a minute then started missing and finally quit. Turns over fine but now will not start. What I have done so far- Set the valve lash at .004", checked push rods-not bent. What I know- plugs are getting spark, they smell like gas so I assume they are getting fuel. Compression is about 65 PSI in both cylinders, squirted oil in each cylinder and compression went up to about 85 PSI. Plugs look dark, strange for new plugs. I have a feeling the cam is faulty and/or compression relief has failed. Anyone have any other suggestion before I get in deeper? Thanks in advance
