gordo2023
- Nov 2, 2023
- 8
At wits end with this machine. New here so please bare or bear with me. Briggs & Stratton 17.5 hp engine no start no spark!
Long story short I had adjusted the valves and apparently did not tighten down the lock screw enough and damaged the intake push rod, broke in half. I replaced the push rod and adjusted the valves, setting them at 5, intake, and exhaust 7 thousandths. I get spark to the plug when grounded to the block but nothing when put in the engine. I have used a light to test the coil as well as a multimeter and it tests ok, in fact new. None of the safety wiring has been touched - brake, seat and kill switch.
What can it be??
What can it be??
