No spark - Gordon
gordo2023
Just because it fires out side the cylinder @ .030 does not mean it will fire under compression. To similate compression the gap outside the cylinder has to be at least 1/4 inch.
gordo2023
I do not follow your thinking! Are you referring to the plug gap or the spark arc?
hlw49
you have to have a tester that has a gap of at least 1/4 inch gap for the spark to jump
gordo2023
After so many attempts I, using advice from others, decided to check the valves again and found I did not have the exhaust push rod in place! The engine started when fixed but knocked loudly and finally died. Do not know where to go from here!
Tiger Small Engine
The push rod sits in a tiny indentation on the tappet, down the cylinder head valve valley. When you think you have push rod in correct place, rotate the engine to make sure intake and exhaust valve are moving. Then you have to set the valves to correct clearance. If you do not know how to set valves, take it to shop, don’t guess.
gordo2023
gordo2023
Why the loud knocking and then dying after a start-up?
