Hottech
- Jun 22, 2019
- 15
Plug works fine in my other mowerif these are plugs that came from an online source, you may have a whole run that are counterfeit or defective.
New coil arrives on Monday.
Briggs and Stratton single cylinder v tech has a strong spark from the coil utilizing a tester but no spark from the plug. Replaced the plug but still no spark. Asked a mechanic and he said that he would first just replace the coil. Ordered a new coil and hope that it will fix the problem but not too confident since the original coil has a very strong spark. Any suggestions would be appreciated
How old is this coil? If it has switching transistors they can become weak after years of use. You should see a bright blue spark and audibly hear the snap from the spark.Briggs and Stratton single cylinder v tech has a strong spark from the coil utilizing a tester but no spark from the plug. Replaced the plug but still no spark. Asked a mechanic and he said that he would first just replace the coil. Ordered a new coil and hope that it will fix the problem but not too confident since the original coil has a very strong spark. Any suggestions would be appreciated.
