Cheeseoreno
- Feb 9, 2020
- 7
There is no power going to the trigger wire (Blue) at bottom of solenoid which looks like a car starter (Starter attached to a tube solenoid). One Red Wire on top connection to Starter direct from Battery. Tested PTO, Starter Switch, Ammeter, Seat Switch and Brake Clutch switch. All switches has continuity. Pulled 7-Blade Plug from Starter Switch and tested for voltage at M or B...no power. Tested voltage across Fuse...no power and Fuse is good. Anyone have any thoughts?
