gregjo1948
- Nov 28, 2012
- 75
- 361
Linkage seems fine but, I don't have forward drive on the left side. Had the drive motor apart, found nothing wrong and install new gasket kit. Removed the pump oil out going lines and plugged the ports. Running the engine at low rpm and moving the drive lever, it would stall the engine. Removed the pump and disassembled and found nothing that appeared to be faulty. Anyone have an idea on what is the reason that I don't have forward drive on the left side? thank you, gregjo1948
