- May 6, 2010
- Threads
- 51
- 11,394
Correct. the pistons will have to be set individually.TDC on each piston, right?
Fresh sealant on the valve covers ,could be someone installed new exhaust valves & didn't set the them. Just a guess.Hello, again. If no compression on either cylinder but pistons still move in and out, what does that mean? I see what looks like fresh sealant on both valve covers? What steps should I take next? Has 142 hours on it.
