So here is where I am at.
Removed the brake casing, have new one coming rather than drill and tap the bolts. How do I get the turning mechanism off the top? Is the bolt reverse threaded or do I just turn to the stop then apply torque?
Also, the spline will only spine when tractor is driving, correct? Cause it is jot moving with the wheels.
In air, wheels spun opposite directions, brake off obviously. Put the tractor back on the ground with the brake spline fully exposed, rotor sitting on a table. I can push forward and the tractor will move with some resistance. Will not push in reverse (should it?) Need to lift and pull to bring back to work area.
Bracket for push pull still appears frozen where it would be if the rod was retracted in drive position. I am imagining that the bracket should turn freely maybe 45 degrees or so towards the back which disengages everything. Then will spring back forward to its present position for driving. If some one can please confirm that so I know if I need to keep working on freeing that up.
Still need to finish the engine this coming weekend and the I can just test drive the thing to see if it all works.
Thanks
