Yeah, I was pretty happy to get it for $50 and am glad how things are going so far. I had a single 16.5HP or so that dropped a valve seat which caused the valve to break off in the cylinder. This was then forced through the head and destroyed it. The piston was dented and likely weakened. I found a used head and installed it. I set the valve lash to spec and went on with business. It ran well for a while and then the same thing happened again with the other valve. This time it busted a hole in the piston and I junked the unit and replaced it with a 16HP Kohler Command which has been excellent.
The fins on this Intek were pretty clean. I had the housing off to do the work and it looked like there wasn't any debris blocking the fins so hopefully it was kept cool. The oil was dirty and pure black but the insides of the valve covers were clean when I checked the lash (it was right on). The valve covers are always where the sludge forms because of their relatively cool temps so was happy to see that they were clean.
I got the fluid in the transaxle changed as well and have started using it to mow. There are a few other little things I need to do but overall the project of bringing my LGT 2554 back to life is completed.
This seemed to mow well but I only have one issue. The engine seems to run-on and diesel after I turn it off, sometimes with loud backfires. This also happens if I happen to raise up off my seat while mowing. I suspect the anti-backfire solenoid is giving me issues as these seem to do more harm than good from my experiences. Usually shutting down with the deck engaged will stop this but this one will actually continue to mow with the key off. Pulling the choke kills it but I hate flooding the engine with all that gas.
The engine definitely ran smoother with more use. Maybe there are deposits from the rich running that are now burning off. I did install new plugs at the same time I solved the flooding issue so assume it isn't the plugs.
