SeniorCitizen
- Aug 28, 2010
- 131
- 2,159
Check the float needle valve for proper fuel level function and change that leaking gasket or you'll never get it to run like it should. Nothing should be dripping there and when it isn't dripping it is sucking air.. (bad gasket from carb to engine as it leaks a drip or so every 10 seconds- will change after getting it to run)
This really seems impossible so possibly I'm not understanding what gasket you are speaking of.
