- Dec 7, 2022
- 2,298
Lucas or Mystic grease red and tacky.It could be you are side loading the bearings too much. Try loosening the retainer and test. It tuns out to be side loading problem then the spacer is a hair too short.
Don’t just spin spindles and pulleys, grab them and twist up and down for play. Something is making that howling noise. If you have not been greasing them regularly in four years, that will add to the noise.
