Consumate Tinkerer
- May 20, 2022
- 2
I own a self-propelled, electric start. Lawn Boy model 8241AE that I bought new in 1985 and today still use religiously (mainly as a trim mower or to collect clippings). The mower looks its age and has experienced several mechanical problems in it life, but nothing major that I couldn't correct myself. But over its 37 years of use the rollers on on either end of the drive shaft - which press down on the rear wheels to propel the mower, no longer engage the wheels properly. Despite being of metal construction, the rollers appear to have some concave wear on them. By the same token, over the mower's long years of use, I would surmize the tread on the rear wheels has worn down to an extent contributing to the problem. I would be interest to know what would be the most economical fix - replacing the rollers, the wheels or both (if they're still available). Initially I gave thought to epoxying lead-impregnated rubber strips around the rollers to increase their circumference to make solid contact with the wheel, but then I started second-guessing myself. I would welcome any suggestions or recommendations on how to fix this problem. Much like many of your contributors, I'm and old guy with bad knees and rely on the self-propelled feature to get the mower up hills without straining myself to push it.
Thank you.
Thank you.
