New pulley bearing not smooth
bassadict69
I bought a new idler pulley for my ZT HD52...when spinning the shaft to check the bearing, it has a spot that you can feel it sort of bump when spinning it. I don't know how to really explain it. Is it a bad bearing? I assume I need to get another pulley?
I would agree it is a bad bearing as I have had to idlers out before that would end up snapping belts because of one rough spot which is worst under load.
