New Member 2011 troy built hooked up battery charger backwards?
bigmiketx
  • / New Member 2011 troy built hooked up battery charger backwards?
After couple adult beverages I hooked up battery charger backwards trying to get general idea things that I may have to check in trouble shooting this screwup of mine,I thought battery would be smoked ,solenoid i was surprised to see that I\the fuse wasnt blown going to soleinoid any ideas?:ashamed:
RDA.Lawns
Was the key on? Chances are higher than not that nothing is hurt if it wasn't hooked up long or the key was off. Newer battery charges have polarity protection in them.
Fuse actually comes from the solenoid not to the solenoid.
Most battery chargers are reverse polarity sensitive and trip out if hooked up backwards.
If the mower was turned off then the only thing that could be damaged is the battery.
Mower turned off + no power going anywhere so no fuse to blow.
Catherine
LawnWorld Support
Welcome to the forum!
I'm going to move this thread over to our Troy-Bilt section. :drink:​
7394
I only use Battery MINDers* anymore. Hook it up & forget it. Can't overcharge & has an external temperature compensator to raise or lower floating voltage as air temps require.
bigmiketx
That is good news.Thank you.
