New kid on the Block
Here's my Summer /Fall Tech Tip from Charlie's small engine FB Site . Make sure you run all of your two and four cycle equipment every month . even if your not going to use it . this will help to keep the Ethanol fuel from NOT drying up inside the carburetor on your unit thus clogging it . and If your NOT going to use the Piece of equipment (Say over two months ) then REMOVE the fuel completely . Have a great day Y'all
Thanks for the tip, Charlie.
I have a better tip: Move to a State where NON-ethanol gas is readily available.........carb problems VANISH !!
I know Texas has some weird laws concerning availability of non-ethanol fuels..........
The customers all get told to tip the fuel out, then start the engine & run it dry.
Those that do it have no problems , those who don't contribute to my retirement fund.
Now the only mixing bottles in the shop are 1 litre or 500 ml so the fuel will always be fresh.
I believe Walmart sells non ethanol fuel ..
I know guys in the repair biz that Dont say chit about it and keep the work coming back . Dumb Real dumb . good way ta piss a cust off .
:welcome:
Welcome to the forum!
Sorry about the 5-posts rule, but it helps to keep the spammers at bay.
Not a problem Catherine . im all so a member of a Slot players forum (oddly with the same screen format ) Called Jokers Wild slot Forum they have a ten post rule there . so ive seen it before .
