New-ish Simplicity Regent - No headlights
cpalma
Hi All,
I'm new to the forum, and happy for any advice folks can provide. I bought my Simplicity lawn tractor about 10 months ago and it has been running like a dream until last week when the engine would not turn over. I put a battery charger on it and got it started (not yet sure if battery will hold the charge) but I noticed the head-lights don't work.
Could this be related to a weak battery? Do I have an alternator issue? All thoughts welcome.
Thanks!
Start your tractor and set at full throttle. Take a voltage reading across the battery terminals. If it is charging you should get between 13.4-14.2V DC. If below that we will have to check to see why. Please post back results and engine model numbers.
EngineMan
Does it have a Dual Circuit, AC for lights DC for battery and run...? post up engine/type numbers
That's why I want the numbers to see what we have. What color and type of plug comes off the engine?
Briana
Welcome to LawnMowerForum!
I moved your thread to the Simplicity Forum. :smile:
