Hello,
I have a new Raptor (52 inch cut, 24 horse power, Kohler engine.)
I found what I think is the drain valve near the oil filter (it's a new Raptor, first oil change) and there is no knob on it so I suspect I have to use a adjustable wrench to open it? And when I do, it looks like it will drain oil on some of the mowers support by the wheels.
Do I need a hose to drain the oil (sticking it in the valve opening)?
thanks,
Deaf
I have a twin engine boat that is impossible to get a oil drain pan under so I purchased a oil pump out device and now use it on everything. I think it was a couple hundred bucks from a marine store but it makes everything so easy and no mess. Stick a tube down the oil stick hole, turn it on and go have a beer. When I return I change the oil filter and fill it up with fresh oil. I don't think it removes all the oil so I change it a little more often than recommended but the convenience is worth it.
