New HRX, smells hot
TLAR640
I realize run time depends the height and thickness of the grass being cut, but my mower runs about 70 to 80 minutes per tank.
KrashnKraka
A "hot" smell on a new engine is normal.
All those internal parts are settling into a new relationship. The piston rings are in a um, discussion with the cylinder wall and each are flinging microscopic bits of metal at each other trying to establish dominance. The spark plug is the Alpha Male, and causes the fuel and air mixture to explode, which sorta interferes with the piston a bit, causing even more bits to fly around. The valves are desperately trying to referee, but are limited by the camshaft, a by-the-book type, with a precise agenda. In reality, the camshaft is manipulated by the timing belt, who people tend to tread as "the new guy" even though he's been around for almost 25 years. :tongue: :tongue:
All this activity generates a LOT of heat, and the engine block has to put up with all of it. It responds with absorbing a lot, but lets off a bit of an odor in the process. It does not last long, and after a few hours, the stink will go away for good. :thumbsup:
/laughin'/
Like your style fella, true Honda humour :)
You did though omit HilaryFilter who, sitting in her black box, sucks in
all blends of offerings and passes them cleanly to the Alpha male who
promptly morphs good air to foul gas emissions, even after shutting
down for a snooze.
Kinda like my partner providing a great kitchen output :)
/waves/
KK
----- no intended slight on a likely presidential candidate who may say, one day
"I did not have sex with THAT man, we are just certified friends"
