- Feb 19, 2020
- 121
- 12,895
Have check the resistance of the electric clutch coil? If partially shorted they can still operate but draw excessive current which overload the charging system. I seen these clutches to pull nearly 20 amps and still operate. Normal minimum resistance is around 1.7 ohms any below that indicates a shorting winding. Also most electric clutches pulls under 7 amps with 3-5 amps being closer to normal draw.
