MowerMike
- Sep 5, 2012
- Threads
- 85
- 964
Greenworks has introduced a new heavy duty lineup of 60 volt OPE that they have named X-Range. These tools have durable magnesium housings and other features to make them suitable for hard commercial use. They also have a new lineup of batteries that can connect to smartphones via Bluetooth to lock them, locate them and monitor them. According to Greenworks, these batteries are interchangeable with the previous series 60 volt batteries and will work in all 60 volt tools. Notably, there is a new 8 Ah battery that is one inch longer than the lower capacity versions, such that it will not fit in some tools which have battery compartment covers. The X-Range tools are all sold as Tool Only.
Another intriguing tease are some images that suggest that riding mowers are coming in the future, similar to the new EGO ZTR Z6.
Pro 60V 16" Brushless Bike Handle String Trimmer (Tool Only)
4 Year Limited Warranty
www.greenworkstools.com
Pro 60V Brushless Backpack Blower 560 CFM (Tool Only)
X-Range 60V 10" Brushless Telescoping Pole Saw (Tool Only)
60V 20-Inch Cordless Pole Hedge Trimmer | Greenworks Tools
Our 60V Cordless Pole Hedge Trimmer has a professional-grade brushless motor and laser cut, hardened steel blades for clean & fast cuts. Order today!
Greenworks X-Range 21 in. 60V Battery Walk Behind Push Mower (Tool-Only)-60LM21P - The Home Depot
The 60LM21S 60-Volt Lawn Mower features a professional grade brushless motor for gas-like power. Choose from 3-in-1 mulching, bagging and side discharge capability for your desired results. Select your
www.homedepot.com
