Zeroprogress
- May 1, 2022
- 3
I have a new JD Z930r that has 7.5 hours on it. I noticed an oil leak under the drain plug of the 25.5 hp Kawasaki engine after the first mow at about 3 hours. At first I blamed it on the cheap plastic oil drain valve. However after changing the plastic valve to the Kawasaki drain hose with brass ends, oil is still leaking when I mow. I checked the oil filter area, oil pressure sender and new oil drain hose. All are dry. It’s under those items on the frame surface that it’s pooled up. It’s kind of a wide pattern with some higher splatters but all in the area beneath the oil drain It’s leaking to the tune of about 1/2 quart per 3 hours. From underneath I do not see anything like a crack in the case or any other source for the leak. The only area I can’t see is under the oil pan but since I have ruled our most visible things am thinking the only possibility is the crank seal. I welcome any ideas on this but of course beyond anything simple I will have to have the machine picked up for JD warrantee work. (Meaning it’s gone for???!!!)
