LarryJohnson
- May 30, 2017
- 142
The pulleys began whisling because they were spinning about 5000rpm. bearings are good.If you can make the pulleys whistle when you blow air on them, I would say the bearings are worn. A good bearing should not make noise. That and a slightly short belt will heat up quickly.
Untitled
Untitled
