New bobcat zt2000 mower deck very noisy dealer put new belt still noisy
Jjhuff
  • / New bobcat zt2000 mower deck very noisy dealer put new belt still noisy
Right, and that is causes you a noisy deck, Dude you need to get a better dealer. r
Yes I sent my complaint to bobcat I’ll see what happens
Jjhuff
I have called bobcat to see what the have to say very disappointed in this zt2000 bobcat mower with 18 hrs.
Jjhuff
I would never buy another bobcat mower
Honest Abe
you'll need a helping hand here, while the deck is running, "carefully" take a long screwdriver and touch toward the center each rotating pulley and idlers. If the noise you're hearing changes, then you've probably found your culprit. But, as I've already stated - be carefully when doing this . . . .
Jjhuff
Jjhuff
Well now it’s backfiring when I shut it off they are coming to get it I would not recommend anybody ever buy a zt2000 bobcat zero turn what a piece of absolute junk with 20 hrs on it very poor quality mower
jandtshipp
I like mine. 68 hours so far. How’s yours doing now?
Jjhuff
Deck still noisy have had it looked at by 2dealers cuts nice and runs good I think it just the design of deck oh well
DanDavis_
I don't actually have a bobcat zt2000 but my brother does have one (Im not sure the model is 2000). His machine also had this problem. It's possible that the racket is coming from the deck's design, or maybe there's an issue with the deck wash system that's letting water seep into the bearings, causing them to go wonky. You might wanna take a peek at those bearings on your deck
hlw49
We have fought the belts like that on several mowers. Finally got an after market raw edge belt and it solved the problem. Dealer is right the wrap belts can cause a noisey deck. Like he stated ever where there is a joint in the wrap there is a bump in the belt. I have seen belts with four to five joints in the belt. That coupled with the sorry new PEER spindles that a lot of mower have on them. Too much end play and they can get really noisey. Took the spindles to a machine shop were he machine the spacer down to take out the end play. That coupled with a new raw edge belt, finally got the deck quite enough to satisfy the customer.
