NorthBama
- May 28, 2014
- 9
- 936
was the engine unbolted to get the old belt off if so was it fastened back in the same spot. Sometimes when the pulley is rusted on the engine shaft i unbolt the engine from the frame and slide it back to clear the belt keepers. This would make the belt loose if not back in position. Just searching for clues. looks like the belt is routed correct.
