New all trail tires
JD75
I just got new Carlise All Trails on my JD x320. I was wondering what psi I should put in them to get the max amount of traction.*
A good way to tell is put a straight edge over the treads and add air just till the middle of the tire starts to round out
Sent from my iPhone using LMF
Ok, the tires call for 22 psi and I put 20 psi on them so there is a little more tread on the ground. Not sure if my thinking is correct but it's worth a shot
I am running the 23-10.50-12's on my 582 Cub at 12. Been great so far but they have only been on it for a week or so.
I'm running the all trails. I couldn't find the factory ones to fit. The all trails are 4 ply and the factory ones are 2 ply.
Ok. That was the reason I purchased the All Trails also (4 ply). I don't know that the 2 ply field Trax would have held up to some if the abuse that I put my tractor through. Especially when hauling fire wood out of the woods when I am pulling heavy loads and there is often under brush that likes to ruin a good set of tires.
I have been extremely happy with the All Trails performance and don't have a problem with them tearing up grass like your typical Ag Tire does. I would recommend them to anyone considering a HDAP tire.
