I have a 16 HP Briggs and Stratton that will not stay running..It will start up fine but after putting it in gear and go about 2 to 10 ft it will start back firing through the carburetor and more or less shut down and then when the rpm's are almost down to zero it will start back up but will repeat that same process...I replaced the fuel pump, sanded the outer stater , took the carburetor apart and make sure there wasn't any blockage, and checked the floats for any holes..Is there anyone that might be able to give me any advice on what might be something that I can check would greatly be appreciated..Respectfully Wm
