Bought a week ago, dealer delivered. 1.5 hours on meter, brand new.
Cut is great, all is well. However, it was pulling to the left. Called a dealer, got with a tech, he explained and I was able to adjust hydro and made it run straight.
After first run - hydro oil tank was empty. Had to go get quart, no big deal, but still...
While I was doing that - found 2 bolts missing. One bolt on a plastic cover and one bolt that fixes adjustment of arm(!).
Ok, joked with a dealer about "Friday's assembly". They mailed bolt (one), put it in, life is good.
Today, 2.1hr on meter, I started to mow. 5 minutes later started to hear noise from a deck. Finishing pass, parking on a pavement and noticed hole in a black belt cover. It was melted!
Taking cover off - pulley off, bolt loosened on right belt pulley. Belt off. Center blade pulley bolt ALMOST out as well.
So, pulley and cover need to be replaced (at least). And I'm not sure what is going to fall out next? Called a dealer - he said he will check if Husteler will pay him for Pickup. I'm really upset, 3rd of a front yard mowed and how long will it take to fix??
