Need to know what this is called or part number
Jayp1017
Can anyone tell me what this spring and hand nut are called. Trying to locate the spring and screw in the picture but dont know what to search for. Tried "governor adjustment screw" but nothing I'm seeing. Might someone be able to point me in the right direction? Maybe a link?
Post the numbers off the shroud and I’ll get you a part number.
Jayp1017
Unfortunately I dont see any stickers to indicate its year or model. "J607" It was on an exmark power rake model ra-5000. Best I could find as shown in pic looks like same motor on 1976 5hp briggs.
It called a thumb or governor screw [depends on where in the service manual you find it] and the rod is the governor adjustment rod but we do need model and type number that is stamp into the metal of the engine shroud. Look carefully on this older unit the shroud may have been repainted. These number usually on the flat area on the head side the shroud. I have had to sand or scrape paint off a few time over the years to reveal the number.
Oops.
Removed and put in the correct thread.
Jayp1017
Model
1 30202
Type
2142 01
Code
86092907
1 30202 2142 01 86092907
I'd appreciate a diagram or link or both?
Thanks for your help!
Format the model as 130202-2142-01 and your unit is a 1986. Google this number for IPL.
Extract the Power Portal provided IPL. Note two thread pitches are possible 5-44 and 6-32.
206B 94081 NUT -Used After Code Date 84042900
206B 93422 NUT -Used Before Code Date 84043000
206A 280012 NUT, Governor Adjusting
206 230149 NUT, Governor Adjusting -(5-44) -Used Before Code Date 84043000
206 231266 NUT, Governor Adjusting -(6-32) -Used After Code Date 84042900
207 26855 SPRING, Governor Link
208 230737 ROD, Governor Control -(5-44) (9-1/8) -Used Before Code Date 84043000
208 230946 ROD, Governor Control -(9-1/8) -Used After Code Date 84042900
208 261985 ROD, Governor Control -(6-32) -Used After Code Date 84042900
Jayp1017
Thanks so much! I appreciate the help. I just need the spring and the nut. What is IPL? Not really finding anything.
