Just had a new engine installed in this unit, and it runs like a champ. Just noticed that the shop did not re-install the wire supplying power to the headlights. It's a small thing, I know, and, having owned this mower since 1987, I believe I've had occasion to use the lights three times. Still, if I can get them to work, it would be nice. The two headlights have a wire that runs between them and are grounded on one side. The "post" where the wire supplying power is empty. I've done a bit of reading, and am guessing that these lights draw power from some connection to the engine, not directly to the battery. I cannot remember if they operated only when the engine ran or if they could be switched on when the starter was simply switched to the on position or even when it was off. There is an "open" plug reeptical down near the oil drain plub that has a yellow wire and a red wire running from it. There is a yellow wire that runs from the light switch, but I have not been able to tell where it goes. The red wire has been cut. I have included a link to four photos that show the above. Note that the red wire coming from the "open" plug looks as though it turns from red to blue, but that is just an optical illusion. Where the red color stops is where the wire is cut.
Any advice much appreciated.
Caruso
Caruso
