mannyrs234@gmail.com
- Oct 5, 2015
- 2
- 5
I have a John Deere L111. Purchased used about 2 months ago. Started mowing grass today and engine (v twin) sputtered. Disengaged PTO. Engine seemed to stabilize but eventually stopped. When I tried to restart engine it wouldn't turn over, click, nothing. After some thought, I jumped the solenoid (like 1950's Fords) and the engine spun like usual - but would not start. Does the solenoid on a JD mower supply power to the starter AND the ignition system? Does the ignition switch supply power to the starter through the solenoid AND supply power to the ignition system? Might I need to replace the ignition switch, the solenoid, or both the ignition switch and the solenoid? Your input would be very much appreciated.[/Q
I'm not interested in swapping out parts. That's why I'm asking and trying to understand how my mower works. Before my 1st post I checked many of the wire connections mentioned; I checked the 20 amp fuse - appears to be fine; I wondered if there were some safety switches but honestly do not know where they might be or what to check; gas is fresh; oil is clear; gas filter appears clear but not full; have not checked spark plugs yet. I'm puzzled by the fact that nothing happens when I turn the key and yet when I jump the solenoid the engine turns like "normal" but engine will not start, which led me to my initial questions.
