Need some advice for a ZTR on a small lot
earthworm
Tbh... if you spend more than an hr on a .4 acre lot your doing something wrong even with a 21"
This, I do NOT know about......as I spend 2 to 3 hours ! .. with the 21 inch LB....I have about 90 obstacles to navigate and 180 "turn-arounds"...or so it seems...
I think a 36" ZTR would be sweet, with mulching capabilities...The 44" Simplicity is a bit too large...
earthworm
That could very well be however this is a brand new house with a new lawn so I have hoses and sprinklers all over the place. My house also has 18 corners. You really need to think about the total time required including all support activities. It is not like the clock starts and stops with the blades on the mower.
1) Get ready to mow. Throw on old clothes and shoes. Get head phones / ear protection (5 min)
2) Get out mower and set up for mulch, throw, or bag depending on lawn conditions. Set proper height. Add gas. Sometimes check oil (5 min)
3) Disconnect all 6 sprinklers and move hoses out of the way (5 min)
4) Tilt up down spouts, remove kid toys, pick up dog crap. Charge up trimmer. (10 min)
5) Mow front left and left side (10 min)
6) Trim mow back (10 min)
7) Mow back (30 min)
8) Mow right side and front right (10 min)
9) Get out blower and house. Clean up mower with blower and washout. Put away (5 min)
10) Get out trimmer, check string, edge driveway, sidewalk, curb 300 ft (10 min)
11) Edge around the house / deck (5 min)
12) Blow off edger and put away. Blow off sidewalk, driveway, and siding. Put away blower (5 min)
13) Hook up sprinklers (5 min)
14) Go inside, take shower (15 min)
This is assuming no additional landscape work and that I'm not bagging the lawn - just over 2 hours start to finish.
The way I see it a ZTR would probably cut 60 min of mowing to 15. Also subtract another 15 minutes depending on the day as may not need to shower. An additional 10 minutes will be saved when I can get rid of the sprinklers.
I suppose when you think of it saving an hour each mow isn't a ton of time but when you have twins every second during the day counts :/
With practice, 10 to 20 % can be cut from each step...But , TKK, you have posted the truth here...we do get too little of this today...
If maintaining a 4.0 acre lawn, the efficiency is much greater...naturally....
earthworm
There's no doubt that the 30 in can get right up in there - probably not much worse than my 22. Only having driven a ZTR once I do not have a feel for what it will miss. Trees appear to be no problem but I have no trees, just a few corners with 3 of them being inside corners that need mowing. I actually plan on making those go away with some rock beds next year. I certainly have a lot to chew on but I believe it is down to the 30 in time master or the timecutter 4260.
As far as the prep time I will see what I can do about that - should be fairly simple, just need to mow in my dress clothes, rip off the down spouts, put away the sprinklers, shoot the dogs, and buy a goat (for trimming). Actually come to think of it I could leave my mower out in the front yard so it is always ready to go. I am still going to clean the damn thing though because like I said it is a POS and clogs up after mowing 3 strips :tongue:
Your new house must include a mud room, This is the place for your work uniform.A firemen is allowed about 60 seconds for a complete change....your time may vary.....
Use automatic roll up downspouts or an underground drainage system, which will run water to your reservoir for gardening.
Use Totes rubbers and shut your eyes ...and nose.....and keep on mowing.....keep the rubbers on the mudroom porch
The goat....a capital idea......seriously....but your yard is too small for this...
I think, that a Worx , would be better and quicker...
Make the mud room large enuff for the Worx, the gardening tools, and the mower....a 36" with non-fixed front wheels.
Remember to lant some trees, this is very important...
