Need large mower for slight hillside... up and down mowing possible
  • / Need large mower for slight hillside... up and down mowing possible
Try this till you get used to the controls.
Use your off hand ( left assuming you are right handed ) to do nothing more than control speed.
So you just move the control from stop to full foreward.
Use your dominant hand to do all the steering so move it backwards & forewards to change direction.
That means for a while you will be making wider turns than you need to but you won't be tearing up the grass or end up spinning around doing 360's till you can not remember where you were going.
Concentrate on that right hand and in no time flat you will find you are doing two hand steering.
It has to come naturally if you concentrate on it you will be driving all over the place.
