Tiger Small Engine
Hope you checked and set valve clearance. I agree with StarTech, in other words, something isn’t adding up.If its weird I'll end up with it lol
Yea it's strange but I removed the valves to make sure the guides weren't slipping out and both valve seals were in place and looked good. This mower has never had any repairs since it was purchased so it's unlikely anyone just threw them in there extra. The holes in the block that the pushrods go into are a perfect snug fit for the seals. Did have one fellow say he had a vw that had seals on the pushrods. Will definately adjust the valves when I get the new seals and reassemble it.Hope you checked and set valve clearance. I agree with StarTech, in other words, something isn’t adding up.
You are correct! duh my brain finally started working and it dawned on my this was a v-twin, took off the other side and no seals! Now still consider this as strange since this mower was purchased new, has never been in a shop for anything, I can only assume these were thrown in there during the original assembly process.Those seals go on the valve stem under the valve spring on the head....no where else. No small equipment engine uses anything on the pushrods.
