I see you already have a lot of advice on this but if you are testing the ignition switch you have to remember you have three different types of voltage going to it. DC positive Voltage, AC positive voltage, and negative voltage. each has its own test and does its own thing. #1 Black is negative feed wire, #2 Red DC positive voltage feed wire, #3 white AC positive voltage feed wire, #4 yellow negative turns off mower engine, #5 orange DC positive activates starter solenoid after it go through safety switches, #6 violet DC positive voltage goes to lamps. Its not hard but you just have to think what type of voltage are you looking for and what does it do. A lot of people don't think as the negative as a voyage but it is and it is just as important as the positive side.
