Information about the riding mower: Craftsman T100 CMXGRAM201302, Model: 13AC77XY093
Hey guys! This is my first post here, not sure if anyone can help with this. I recently had a family member drop their mower off at my house to see if I could fix it for them. They only recently bought it and have been having nonstop issues with it. They’ve already had it repaired in the past but it’s now at the point (past 30 days) where they can’t return it anymore and now the repairman wants $600 to fix it.
When I got it from them, it originally wouldn’t go in reverse and would smell like burning rubber while running. It also ran very poorly despite having hardly any usage. It didn’t take long to figure out what was wrong, it looked like the lower drive belt had slipped off the back dual pulley into the top groove (there’s 2 grooves on this pulley, bottom groove for bottom belt, top for top belt). The belt had been rubbing against the other belt while running, it got pretty torn up and is why it ran poorly. I bought a new bottom belt, top belt seemed okay. After installing it drives fine now but there is a nasty noise coming from the rear and only when I let my foot off the brake/clutch pedal. It's almost like a whine noise. Pressing the brake just slightly is enough to reduce the noise or make it stop. I’m not sure if the noise was there before I replaced the belt as the mower ran so poorly I didn’t notice it.
-I’m not a mower expert but I figured I might be able to save my family some money. I really don’t like this particular mower TBH. I have a 12 year old mower myself that has far less issues than this thing. Anyways, any ideas? Should I just run it and hope the belt "Wears in?" I’m just afraid I might tear up another belt or possibly something much more expensive if I continue using it. Should I tell them to take it somewhere else?
I'll take some photos/videos if anyone is interested in helping. Thanks for your time!
- I’ve googled quite a bit and many people say it was their idler pulley but this lower drive belt has no idler pulleys at all- it goes directly from the main engine pulley to the dual pulley in the back with not possible other routes. It's possible the other (upper belt) may have issues but I haven't touched it. I’ve inspected most of the metal pulleys that I could access with no belts on and they all sound pretty smooth when free rolling.
- Belt looks a little wobbly while running even though it feels fairly tight when the brake is not pressed in. It also seems to get hot (but not scolding hot), as does the metal pulleys it runs on. I’m not sure how hot it’s supposed to be though.
- I lifted the back end and had the mower running full speed with both tires in the air. While the tires are moving in the air (no resistance), there doesn’t seem to be any squealing noise so it’s hard to tell where the sound is coming from exactly. Maybe this could better identify the issue though?
