BashRipRock
- May 7, 2018
- 31
I really appreciate all the info and the effort put forth. I'm in possession of several different manuals for the engine and the snowblower itself. Now I have a couple of questions because I am not familiar with the Tecumseh Engine or the snowblower for that matter. (I know this isn't a snowblower forum) I have a throttle adjustment lever but it doesn't do anything because from what I can tell this engine has a governor on it. Am I correct on this? The throttle lever is hooked to an extension spring. The carb cover is not attached so it rattles something fierce. Can someone please explain to me how to remove the terminal assembly from the carb cover? I didn't have time to figure it out. Because it is riveted on from the outside. So, I have some miscellaneous hardware I need to get. Now the muffler is intact. But good grief a person would go deaf running this unit. I'm guessing the muffler is not working correctly or at all. Any clue how many rpm's this thing goes to? All in all the parts are readily available locally and online of course. I'm not concerned in getting parts, just trying to figure a few things out. Thanks for the help again on this thing. Have a great evening.
