taxidermist
- Jun 4, 2011
- 2
- 112
Check your drive belt again and make sure its on right. Make sure you can turn the motor 360* by hand. If it cranked 1 time your started should be wired right. check all you connections to starter for tightness. If that does not work remove starter and jump it to see if it works off the motor.
Rob
Rob
