wheelie
Re: Need good mechanic..
FIXED
and there we have it..
dug out my fluke and pulled the fuel solenoid.. checked for coil continuity .. it was good. so checked for voltage.. none..almost started the ignition switch but decided different.. hooked ground lead directly to battery and positive to harness connector.. we have voltage.. hooked positive lead to positive on battery and negative lead to harness connector.. nothing... Fuel Solenoid harness ground is right beside carb mount so got felt up to it and it was connected.. by one skinny little corroded strand that immediately broke off.. new connector eye ..clean up the area.. tighten it up.. and hooked to solenoid... hit the key.. and plunger goes in.. test several times.. works.. put all back together.. give a crank .. it is running.. finished mowing my yard and mowed the little gal a crossed the street's yard with purposely shutting down and restarting several times.. all is good and I believe it is running smoother.. might just be my happy self..
Thank You all for your help... friendliness.... and experience... :thumbsup: :cool2:
I am sure I will be back..
