I do not have a model number so i need to back into find a part to fit this Kohler PH-XT149-0316. S/N 4119316388.
Shaft is 25mm Keyway is 3/16". The tapped hole is 7/16-20. All of the online parts listing requires a model number and provides no way to search by engine number. They do not connect the two in the Lawn boy listings.
If someone has a correct part number or can confirm the dimensions on thier machine and then can provide a model number that would be awsome. I am not sure if the Toro blade adaptor parts are interchangable. I think the Toro's use a 1" shaft and have a 3/8-24 tapped hole.
