- Nov 29, 2014
- 24,995
The problem has not recurred for me since that one time. However, I have had something else(possibly related?)the last time I used it. Every time I would engage the blades the engine would stumble, there'd be a puff of fuel smoke, & a second or two clattering(pre-ignition). This went on until I partially finished mowing & parked it for lunch. Went out later & it would not start without full choke or keep running except with half choke.....Fuel smoke fogging out the exhaust.
All I could come up with for a solution is possibly a bad float or float valve, or the general effects of ethanol fuel. So, I ordered some carb parts & cleaned the carb. Got it back together today.
Now it is up & running, but it's still not right. Have to start it with choke & keep it running with half choke until the engine heats up. After that it runs about 95%, but still stumbles & clatters every time I engage the blades.
The only other thing I can think of is the little solenoid on the fuel bowl. This is the 1st one I've seen on a small engine. Does it work with the float to control flow?
Jeff
Start with the quick easy & common. work back to the exotic , rare, difficult & expensive.
Symptoms are consistant with leanness.
2 ways for lean burn, too much air or not enough fuel.
crank engine & check fuel flow to the carburettor from the pump
remove float bowl and clean it.
Check that the solenoid on the float bowl retracts fully when the ignition is turned on . on most they earth out through the case.
crank engine & check fuel flow from the float valve
remove main jet & clean it
